주요 콘텐츠로 건너뛰기
Black and Decker TR1278B Top Cover Replacement
필요한 것
  1. Black and Decker TR1278B Top Cover Replacement, Top Cover: 1 단계, 이미지 1/1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Top Cover Replacement: 2 단계, 이미지 1/1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Top Cover Replacement: 3 단계, 이미지 1/1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Top Cover Replacement: 4 단계, 이미지 1/1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Top Cover Replacement: 5 단계, 이미지 1/1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dominic Gamonez
회원 가입일: 02/15/17
233 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 77
전체 시간: 6,343
