소개
Learn how to manipulate your Black and Decker Toast R Oven in order to clean it, to replace its door-spring mechanism, and/or to replace its damaged door.
필요한 것
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Hi I am doing my own repairs on a black and decker toaster oven and need some help. identifying that part under the oven where the power cord enters the enclosure its actually a disconnect switch to disconnect the power when the door is opened.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
sale humo al momento de prender el horno
