이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
Remove the spring from the door mechanism by pulling it off.
Replace the old spring with a new spring.
Take off the left side of the door by separating the unit from the hinge.
Separate the right side of the door from the unit as in the previous step.
Separate the door mechanism from the door by tilting the door to relieve the mechanism.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
sale humo al momento de prender el horno
