주요 콘텐츠로 건너뛰기
Black and Decker Toast R Oven Door Spring Mechanism Replacement
필요한 것
  1. Black and Decker Toast R Oven Door Spring Mechanism Replacement, How to clean out a Black and Decker Toast R Oven: 1 단계, 이미지 1/1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 2 단계, 이미지 1/2 Black and Decker Toast R Oven Door Spring Mechanism Replacement: 2 단계, 이미지 2/2
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 3 단계, 이미지 1/1
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 4 단계, 이미지 1/1
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 5 단계, 이미지 1/1
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 6 단계, 이미지 1/1
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 7 단계, 이미지 1/1
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 8 단계, 이미지 1/1
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 9 단계, 이미지 1/1
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 10 단계, 이미지 1/1
    • Finish removing the outside cover by lifting the lid upward.
  11. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 11 단계, 이미지 1/1
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 12 단계, 이미지 1/1
    • Now, you can clean the outside units of the toaster oven.
  13. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 13 단계, 이미지 1/1
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  14. Black and Decker Toast R Oven Door Spring Mechanism Replacement, Door Spring Mechanism: 14 단계, 이미지 1/2 Black and Decker Toast R Oven Door Spring Mechanism Replacement, Door Spring Mechanism: 14 단계, 이미지 2/2
    • Use the screwdriver to remove the spring from the unit.
    • Place the screwdriver inside the spring loop.
    • Pull to unhinge the spring from the back panel.
  15. Black and Decker Toast R Oven Door Spring Mechanism Replacement: 15 단계, 이미지 1/1
    • Remove the spring from the door mechanism by pulling it off.
    • Replace the old spring with a new spring.
    • When inserting a new spring, make sure that the spring is connected to the lower hole of the back panel (the hole above is used for the back casing).
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan
회원 가입일: 09/18/12
281 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G10
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Great guide! Very clearly-written and accompanying photos captured the process effectively.
Mo Poppins - 답글
Thanks for sharing,
It's very informative for me, I really enjoy this content.
I also have Content about <a href="https://link accessmastersinc.com/"> emergency gate repair</a>
Cheers.
waleed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 74
전체 시간: 13,459
