이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the toaster door does not stay shut, heat will escape and the toaster will not work properly. This problem can be solved by simply replacing the door spring mechanism.
필요한 것
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Great guide! Very clearly-written and accompanying photos captured the process effectively.
Mo Poppins - 답글
