주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Black and Decker Toast R Oven Knobs Replacement
필요한 것
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: 1 단계, 이미지 1개 중 1개
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: 2 단계, 이미지 2개 중 1개 Black and Decker Toast R Oven Knobs Replacement: 2 단계, 이미지 2개 중 2개
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: 7 단계, 이미지 1개 중 1개
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: 8 단계, 이미지 1개 중 1개
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: 9 단계, 이미지 1개 중 1개
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
결론
To reassemble your toaster, follow these directions in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jonathan
회원 가입일: 09/18/12
320 평판
안내서 5개를 작성함
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G10
4 회원들
안내서 5개를 작성함
1가이드 댓글
very interesting post
James Evans - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 31
전체 시간: 5,551
