주요 콘텐츠로 건너뛰기
Black and Decker Toast R Oven Knobs Replacement
필요한 것
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: 1 단계, 이미지 1/1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: 2 단계, 이미지 1/2 Black and Decker Toast R Oven Knobs Replacement: 2 단계, 이미지 2/2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: 3 단계, 이미지 1/1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: 4 단계, 이미지 1/1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: 5 단계, 이미지 1/1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: 6 단계, 이미지 1/1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: 7 단계, 이미지 1/1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: 8 단계, 이미지 1/1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: 9 단계, 이미지 1/1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
결론
To reassemble your toaster, follow these directions in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan
회원 가입일: 09/18/12
281 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G10
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
very interesting post
James Evans - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 28
전체 시간: 4,670
