주요 콘텐츠로 건너뛰기
Black and Decker WP900 Power Cord Replacement
필요한 것
  1. Black and Decker WP900 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Cord Replacement: 2 단계, 이미지 1/1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Cord Replacement: 3 단계, 이미지 1/3 Black and Decker WP900 Power Cord Replacement: 3 단계, 이미지 2/3 Black and Decker WP900 Power Cord Replacement: 3 단계, 이미지 3/3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Cord Replacement: 4 단계, 이미지 1/1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Cord Replacement: 5 단계, 이미지 1/2 Black and Decker WP900 Power Cord Replacement: 5 단계, 이미지 2/2
    • Gently pull the power cord out from the control module.
    • This is the part to be replaced. Remember to insert the black wire into the top port when installing the new cord.
결론
Cameron
회원 가입일: 02/15/16
231 평판
안내서 2개 작성하였습니다
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 회원
IUPUI-WILSON-S16S8G8
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 282
