주요 콘텐츠로 건너뛰기
Black and Decker WP900 Power Switch Replacement
필요한 것
  1. Black and Decker WP900 Power Switch Replacement, Power Switch: 1 단계, 이미지 1/1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Switch Replacement: 2 단계, 이미지 1/1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Switch Replacement: 3 단계, 이미지 1/3 Black and Decker WP900 Power Switch Replacement: 3 단계, 이미지 2/3 Black and Decker WP900 Power Switch Replacement: 3 단계, 이미지 3/3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Switch Replacement: 4 단계, 이미지 1/1
    • Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Switch Replacement: 5 단계, 이미지 1/2 Black and Decker WP900 Power Switch Replacement: 5 단계, 이미지 2/2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top
  6. Black and Decker WP900 Power Switch Replacement: 6 단계, 이미지 1/1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel will be attached to magnet body.
  7. Black and Decker WP900 Power Switch Replacement: 7 단계, 이미지 1/1
    • Remove the switch from the wires.
    • Gently, pull and release the two wired connections.
    • The switch can now be replaced. Be sure not to damage the two connections to the control module in the process.
결론
Cameron
회원 가입일: 02/15/16
231 평판
안내서 2개 작성하였습니다
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 회원
IUPUI-WILSON-S16S8G8
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 972
