주요 콘텐츠로 건너뛰기
BlackBerry 7100g Battery Housing / Speaker Replacement
필요한 것
  1. BlackBerry 7100g Battery Housing / Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Battery Housing / Speaker Replacement: 2 단계, 이미지 1/3 BlackBerry 7100g Battery Housing / Speaker Replacement: 2 단계, 이미지 2/3 BlackBerry 7100g Battery Housing / Speaker Replacement: 2 단계, 이미지 3/3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Battery Housing / Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Battery Housing / Speaker Replacement, Housing: 4 단계, 이미지 1/3 BlackBerry 7100g Battery Housing / Speaker Replacement, Housing: 4 단계, 이미지 2/3 BlackBerry 7100g Battery Housing / Speaker Replacement, Housing: 4 단계, 이미지 3/3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Battery Housing / Speaker Replacement: 5 단계, 이미지 1/2 BlackBerry 7100g Battery Housing / Speaker Replacement: 5 단계, 이미지 2/2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Battery Housing / Speaker Replacement: 6 단계, 이미지 1/3 BlackBerry 7100g Battery Housing / Speaker Replacement: 6 단계, 이미지 2/3 BlackBerry 7100g Battery Housing / Speaker Replacement: 6 단계, 이미지 3/3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Battery Housing / Speaker Replacement: 7 단계, 이미지 1/1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Battery Housing / Speaker Replacement, Battery Housing / Speaker: 8 단계, 이미지 1/2 BlackBerry 7100g Battery Housing / Speaker Replacement, Battery Housing / Speaker: 8 단계, 이미지 2/2
    • Turn over the motherboard so that the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
  9. BlackBerry 7100g Battery Housing / Speaker Replacement: 9 단계, 이미지 1/2 BlackBerry 7100g Battery Housing / Speaker Replacement: 9 단계, 이미지 2/2
    • The battery terminal is separate from the battery housing.
    • Do NOT get rid of the terminal if replacing the battery housing and/or the speaker.
    • The terminal will slide out of the housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kellan
회원 가입일: 03/30/10
277 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G87
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 4,472
