주요 콘텐츠로 건너뛰기
BlackBerry 7100g Battery Terminal Replacement
필요한 것
  1. BlackBerry 7100g Battery Terminal Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 1/3 BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 2/3 BlackBerry 7100g Battery Terminal Replacement: 2 단계, 이미지 3/3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Battery Terminal Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 1/3 BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 2/3 BlackBerry 7100g Battery Terminal Replacement, Housing: 4 단계, 이미지 3/3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Battery Terminal Replacement: 5 단계, 이미지 1/2 BlackBerry 7100g Battery Terminal Replacement: 5 단계, 이미지 2/2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 1/3 BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 2/3 BlackBerry 7100g Battery Terminal Replacement: 6 단계, 이미지 3/3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Battery Terminal Replacement: 7 단계, 이미지 1/1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 1/2 BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 2/2
    • Remove the four screws holding the battery and speaker housing to the motherboard.
  9. BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 1/3 BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 2/3 BlackBerry 7100g Battery Terminal Replacement: 9 단계, 이미지 3/3
    • Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing.
    • The small plastic piece with four metal pins is the battery terminal shown in the third picture.
결론
Kellan
회원 가입일: 03/30/10
277 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G87
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 3,089
