주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide shows how to replace the BlackBerry 7100g external housing case.
  1. Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. Push down on the release button with one thumb. Slide the battery cover off with the other thumb. Slide the battery cover off with the other thumb.
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. Remove the battery from the battery housing by flipping up the top of the battery.
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. Locate the silver strip near the top of your BlackBerry. Use a plastic opening tool to pry off the edge of the silver lining. Slide the tool along the length of the silver strip to completely remove it.
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. Do not lose the screws. They are quite small and can easily be misplaced. Locate and unscrew the four (4) screws using a T6 screwdriver.
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. The keypad cover may fall out of the housing when prying the housing apart. Tightly pinch the top of the front and back halves of the housing. Carefully pry the two halves of the housing apart.
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. You can now easily remove the "guts" of the phone from the housing.
    • You can now easily remove the "guts" of the phone from the housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kellan
회원 가입일: 2010년 03월 30일
274 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G87
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,163
