주요 콘텐츠로 건너뛰기
BlackBerry 7130e battery replacement
필요한 것
  1. BlackBerry 7130e battery replacement, battery: 1 단계, 이미지 1/1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: 2 단계, 이미지 1/1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: 3 단계, 이미지 1/1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
결론
Sean Tiernan
회원 가입일: 01/20/10
5 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-16, Maness Winter 2010 Cal Poly, Team 3-16, Maness Winter 2010 회원
CPSU-MANESS-W10S3G16
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,996
