주요 콘텐츠로 건너뛰기
BlackBerry 7280 Inner Keyboard Replacement
필요한 것
  1. BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 1/3 BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 2/3 BlackBerry 7280 Inner Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Inner Keyboard Replacement: 2 단계, 이미지 1/2 BlackBerry 7280 Inner Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 1/3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 2/3 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: 3 단계, 이미지 3/3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Inner Keyboard Replacement, Back Case: 4 단계, 이미지 1/2 BlackBerry 7280 Inner Keyboard Replacement, Back Case: 4 단계, 이미지 2/2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Inner Keyboard Replacement: 5 단계, 이미지 1/2 BlackBerry 7280 Inner Keyboard Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Inner Keyboard Replacement, Front Case: 6 단계, 이미지 1/2 BlackBerry 7280 Inner Keyboard Replacement, Front Case: 6 단계, 이미지 2/2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Inner Keyboard Replacement: 7 단계, 이미지 1/2 BlackBerry 7280 Inner Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 Inner Keyboard Replacement, Inner Keyboard: 8 단계, 이미지 1/1
    • To remove the inner keyboard, simply peel it off of the logic board as shown.
결론
Andrew Johnston
회원 가입일: 03/11/13
4 평판
안내서 2개 작성하였습니다
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 회원
CLEM-BENSON-S13S12G2
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 281
