메인 콘텐츠로 스킵하기
소개
The speaker and the LCD screen are one part in the BlackBerry 7280, and both must be replaced if one is faulty. This guide will demonstrate how to remove the screen and speaker after the outer cases are removed.
부품
지정된 부품이 없습니다.
  1. With your thumb press down on the locking- button on the back of the BlackBerry 7280. Slide the battery cover off the device. Slide the battery cover off the device.
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. Remove the lithium-ion battery from the back of the device using your index finger. Remove the lithium-ion battery from the back of the device using your index finger.
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. Hold the device with both hands. Lift the SIM card holder using your thumb and index finger. Remove the SIM card from the device.
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside. The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  6. Use the plastic opening tool to pry the back case away from the front case. Use the plastic opening tool to pry the back case away from the front case.
    • Use the plastic opening tool to pry the back case away from the front case.
  7. Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket. Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket.
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  8. Remove the front plastic case from the metal bracket. Remove the front plastic case from the metal bracket.
    • Remove the front plastic case from the metal bracket.
  9. Use the plastic opening tool to pry at the edge of the screen near the track-wheel. Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
    • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
결론
Sarah Waddill
회원 가입일: 2013년 03월 11일
10 평판
안내서 5개 작성하였습니다
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 회원
CLEM-BENSON-S13S12G2
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 275
