주요 콘텐츠로 건너뛰기
BlackBerry 7280 Microphone Replacement
필요한 것
  1. BlackBerry 7280 Microphone Replacement, Battery: 1 단계, 이미지 1/3 BlackBerry 7280 Microphone Replacement, Battery: 1 단계, 이미지 2/3 BlackBerry 7280 Microphone Replacement, Battery: 1 단계, 이미지 3/3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Microphone Replacement: 2 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement: 2 단계, 이미지 2/2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Microphone Replacement, SIM Card: 3 단계, 이미지 1/3 BlackBerry 7280 Microphone Replacement, SIM Card: 3 단계, 이미지 2/3 BlackBerry 7280 Microphone Replacement, SIM Card: 3 단계, 이미지 3/3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Microphone Replacement, Back Case: 4 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement, Back Case: 4 단계, 이미지 2/2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Microphone Replacement: 5 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Microphone Replacement, Front Case: 6 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement, Front Case: 6 단계, 이미지 2/2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Microphone Replacement: 7 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement: 7 단계, 이미지 2/2
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 Microphone Replacement, LCD Screen and Speaker: 8 단계, 이미지 1/2 BlackBerry 7280 Microphone Replacement, LCD Screen and Speaker: 8 단계, 이미지 2/2
    • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
  9. BlackBerry 7280 Microphone Replacement, Logic Board: 9 단계, 이미지 1/1
    • Use a Torx T6 screwdriver to remove the 3 1/8 inch screws shown.
  10. BlackBerry 7280 Microphone Replacement: 10 단계, 이미지 1/1
    • Remove the logic board with your hands.
  11. BlackBerry 7280 Microphone Replacement, Microphone: 11 단계, 이미지 1/3 BlackBerry 7280 Microphone Replacement, Microphone: 11 단계, 이미지 2/3 BlackBerry 7280 Microphone Replacement, Microphone: 11 단계, 이미지 3/3
    • Remove the small black rubber microphone by sliding it off of the metal bracket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Catlin
회원 가입일: 03/11/13
16 평판
안내서 3개 작성하였습니다
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 회원
CLEM-BENSON-S13S12G2
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Hi ! great tutorial ! do you know the reference name or number of the microphone that this blackberry uses ?
Thank you !
DearTom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 230
