주요 콘텐츠로 건너뛰기
BlackBerry 7510 Back Face of Phone Replacement
필요한 것
  1. BlackBerry 7510 Back Face of Phone Replacement, Back Face of Phone: 1 단계, 이미지 1/1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Back Face of Phone Replacement: 2 단계, 이미지 1/1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Back Face of Phone Replacement: 3 단계, 이미지 1/1
    • Lift off the back cover.
  4. BlackBerry 7510 Back Face of Phone Replacement: 4 단계, 이미지 1/1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Back Face of Phone Replacement: 5 단계, 이미지 1/2 BlackBerry 7510 Back Face of Phone Replacement: 5 단계, 이미지 2/2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
결론
Nick Alejandro
회원 가입일: 01/24/10
3 평판
안내서 1개 작성함
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 회원
CPSU-REGAN-W10S14G44
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,543
