주요 콘텐츠로 건너뛰기
BlackBerry 7510 Logic Board Replacement
필요한 것
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: 1 단계, 이미지 1/1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: 2 단계, 이미지 1/1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: 3 단계, 이미지 1/1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: 4 단계, 이미지 1/1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: 5 단계, 이미지 1/2 BlackBerry 7510 Logic Board Replacement: 5 단계, 이미지 2/2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: 6 단계, 이미지 1/1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: 7 단계, 이미지 1/1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: 8 단계, 이미지 1/1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: 9 단계, 이미지 1/1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: 10 단계, 이미지 1/2 BlackBerry 7510 Logic Board Replacement: 10 단계, 이미지 2/2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: 11 단계, 이미지 1/2 BlackBerry 7510 Logic Board Replacement: 11 단계, 이미지 2/2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
결론
Neil Johnson
회원 가입일: 01/24/10
12 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 회원
CPSU-REGAN-W10S14G44
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,850
