주요 콘텐츠로 건너뛰기
BlackBerry 8700c Replacing Logic Board Replacement
필요한 것
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: 1 단계, 이미지 1/2 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: 1 단계, 이미지 2/2
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: 2 단계, 이미지 1/2 BlackBerry 8700c Replacing Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: 3 단계, 이미지 1/1
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: 4 단계, 이미지 1/2 BlackBerry 8700c Replacing Logic Board Replacement: 4 단계, 이미지 2/2
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: 5 단계, 이미지 1/2 BlackBerry 8700c Replacing Logic Board Replacement: 5 단계, 이미지 2/2
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: 6 단계, 이미지 1/3 BlackBerry 8700c Replacing Logic Board Replacement: 6 단계, 이미지 2/3 BlackBerry 8700c Replacing Logic Board Replacement: 6 단계, 이미지 3/3
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
결론
arlebrun
회원 가입일: 12/02/09
1 평판
안내서 1개 작성함
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 회원
CPSU-MANESS-F09S18G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 3,244
