주요 콘텐츠로 건너뛰기
BlackBerry 8703e Battery Replacement
필요한 것
  1. BlackBerry 8703e Battery Replacement, Battery: 1 단계, 이미지 1/2 BlackBerry 8703e Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: 2 단계, 이미지 1/1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
결론
Johnathon Gorski
회원 가입일: 01/13/10
22 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-3, Forte Winter 2010 Cal Poly, Team 11-3, Forte Winter 2010 회원
CPSU-FORTE-W10S11G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 4
전체 시간: 3,386
