주요 콘텐츠로 건너뛰기
BlackBerry 8703e Case Replacement
필요한 것
  1. BlackBerry 8703e Case Replacement, Battery: 1 단계, 이미지 1/2 BlackBerry 8703e Case Replacement, Battery: 1 단계, 이미지 2/2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Case Replacement: 2 단계, 이미지 1/1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
  3. BlackBerry 8703e Case Replacement, Case: 3 단계, 이미지 1/2 BlackBerry 8703e Case Replacement, Case: 3 단계, 이미지 2/2
    • Make sure the back of the phone is facing upwards like the image on the left.
    • Remove all three screws highlighted in the image by turning them counter-clockwise using the T6 Torx Screwdriver.
  4. BlackBerry 8703e Case Replacement: 4 단계, 이미지 1/2 BlackBerry 8703e Case Replacement: 4 단계, 이미지 2/2
    • Locate the notch in the back of the phone.
    • Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
    • Slide the opening tool in between the two halves of the phone.
    • Continually apply upward pressure with the opening tool to pop the back casing off of the main body.
    • Set the back casing aside and out of the way.
    • You should now have five parts: The battery cover, the battery, the screws, the back casing, and the main body of the phone.
  5. BlackBerry 8703e Case Replacement: 5 단계, 이미지 1/1
    • Do not separate the front casing from the rest of the phone during this step. Keep the phone face-down on a flat surface.
    • Remove these four screws by turning them counter-clockwise with the T6 Torx Screwdriver.
  6. BlackBerry 8703e Case Replacement: 6 단계, 이미지 1/3 BlackBerry 8703e Case Replacement: 6 단계, 이미지 2/3 BlackBerry 8703e Case Replacement: 6 단계, 이미지 3/3
    • Hold the phone so the screen faces downward like in the first image, and remove the front casing.
    • Remove the two keyboard components from the front casing, then set them aside.
    • If the components or a black port protector fell out while removing the front case, then still set them aside. Take note that the two keyboard components may remain stuck together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathon Gorski
회원 가입일: 01/13/10
22 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-3, Forte Winter 2010 Cal Poly, Team 11-3, Forte Winter 2010 회원
CPSU-FORTE-W10S11G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 4,762
