주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry 8820 LCD Screen Replacement
필요한 것
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 BlackBerry 8820 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 BlackBerry 8820 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1개 중 1개
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 BlackBerry 8820 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 BlackBerry 8820 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 BlackBerry 8820 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
결론
작성자
8다른 기여자 명과 함께
ryan
회원 가입일: 04/12/13
44 평판
안내서 5개를 작성함
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G64
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 58
전체 시간: 984
