주요 콘텐츠로 건너뛰기
BlackBerry 8820 Motherboard Replacement
필요한 것
  1. BlackBerry 8820 Motherboard Replacement, Disassembling BlackBerry 8820 Outer Casing: 1 단계, 이미지 1/1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Motherboard Replacement: 2 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: 3 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement: 3 단계, 이미지 2/2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Motherboard Replacement: 5 단계, 이미지 1/1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the bottom casing clip, it will easily unsnap when pulled
  7. BlackBerry 8820 Motherboard Replacement: 7 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement: 7 단계, 이미지 2/2
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
  8. BlackBerry 8820 Motherboard Replacement: 8 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement: 8 단계, 이미지 2/2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector
    • When removing the ribbon cable handle with care; it is prone to breaking
  9. BlackBerry 8820 Motherboard Replacement: 9 단계, 이미지 1/2 BlackBerry 8820 Motherboard Replacement: 9 단계, 이미지 2/2
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
    • Using the prying tool, lever up the old screen as shown.
  10. BlackBerry 8820 Motherboard Replacement: 10 단계, 이미지 1/3 BlackBerry 8820 Motherboard Replacement: 10 단계, 이미지 2/3 BlackBerry 8820 Motherboard Replacement: 10 단계, 이미지 3/3
    • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
    • After you remove the old motherboard, you can then replace it with a new one.
결론
다른 3명이 해당 안내서를 완성하였습니다.
ryan
회원 가입일: 04/12/13
44 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G64
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 910
