소개
This guide will demonstrate how to remove the trackball on a BlackBerry 8820. To reassemble the device, please follow the instructions provided in reverse order.
Always exercise caution when handling electronic components.
필요한 것
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
After removing the front from the outer casing, the track ball will come off attached to the casing.
다른 3명이 해당 안내서를 완성하였습니다.
