주요 콘텐츠로 건너뛰기
  1. Press down on the battery release button and slide the back cover up with your thumb.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Pry from the top of the battery to pull it out.
    • Pry from the top of the battery to pull it out.
  3. Slide the metal sim card cover to the unlock position.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Remove the two T5 Torx screws circled at the top of the phone.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Remove the red cover at the bottom of the phone.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Be careful not to damage the front cover's plastic clips while trying to separate it from the phone. Use a spudger to pry the front cover away from the side panels. Work the spudger around the entire phone until the front cover is free.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Remove the keyboard.
    • Remove the keyboard.
  8. Remove the four T6 Torx screws located on the corners of the keyboard frame.
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Now remove the left and right side panels. Now remove the left and right side panels.
    • Now remove the left and right side panels.
  10. Remove the keyboard frame. Be sure to unhook the screen housing from the motherboard before continuing.  Refer to the square indicated in the second picture. Now remove the screen housing.
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. Unplug the ribbon cable from the board.
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. Insert tool between LCD screen and board.
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mandy Chan
회원 가입일: 2012년 01월 20일
91 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G32
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,621
