주요 콘텐츠로 건너뛰기
BlackBerry Curve 8310 Trackball Replacement
필요한 것
  1. BlackBerry Curve 8310 Trackball Replacement, Battery: 1 단계, 이미지 1/1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 Trackball Replacement: 2 단계, 이미지 1/1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 Trackball Replacement, Lens: 3 단계, 이미지 1/1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 Trackball Replacement: 4 단계, 이미지 1/1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 Trackball Replacement: 5 단계, 이미지 1/1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 Trackball Replacement: 6 단계, 이미지 1/3 BlackBerry Curve 8310 Trackball Replacement: 6 단계, 이미지 2/3 BlackBerry Curve 8310 Trackball Replacement: 6 단계, 이미지 3/3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 Trackball Replacement, Keyboard: 7 단계, 이미지 1/1
    • Remove the keyboard.
  8. BlackBerry Curve 8310 Trackball Replacement, Trackball: 8 단계, 이미지 1/1
    • Use a spudger to pry off the plastic ring surrounding the trackball.
  9. BlackBerry Curve 8310 Trackball Replacement: 9 단계, 이미지 1/2 BlackBerry Curve 8310 Trackball Replacement: 9 단계, 이미지 2/2
    • Remove the trackball from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sean Willis
회원 가입일: 01/26/12
229 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G32
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 3,782
