주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Use this guide to replace the motherboard of your BlackBerry Curve 8520.
부품
지정된 부품이 없습니다.
  1. Insert a plastic opening tool into the small notch on the rear cover of the phone. Pry the rear cover up from the phone.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. Locate the slit between the top of the battery and the casing. Gently apply pressure on the top of the battery to trigger the spring release.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. Remove the two Torx T6 screws to the left and right of the battery. Remove the two Torx T6 screws to the left and right of the battery.
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  5. Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath. Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  6. Insert the plastic opening tool in the seam along the side of the device. Slide the tool along the length of the seam, applying moderate force with the plastic opening tool. Carefully remove the faceplate.
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  7. Remove four T6 Torx screws from the front of the phone. Using tweezers, remove the keyboard buttons from the phone. Using tweezers, remove the keyboard buttons from the phone.
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  8. Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone. Remove the four T6 Torx screws from the corners of the keyboard.
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  9. Using a plastic opening tool, gently pry the motherboard assembly from the device's frame. Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
결론
다른 31명이 해당 안내서를 완성하였습니다.
Matt
회원 가입일: 2011년 04월 07일
1,710 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G62
5 회원들
안내서 5개 작성하였습니다
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 22
전체 시간: 36,151
