주요 콘텐츠로 건너뛰기
BlackBerry Curve 8520 Motherboard Replacement
필요한 것
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: 2 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement, Battery: 2 단계, 이미지 2/2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 3 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 3 단계, 이미지 2/2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: 4 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: 5 단계, 이미지 1/3 BlackBerry Curve 8520 Motherboard Replacement: 5 단계, 이미지 2/3 BlackBerry Curve 8520 Motherboard Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: 6 단계, 이미지 1/3 BlackBerry Curve 8520 Motherboard Replacement: 6 단계, 이미지 2/3 BlackBerry Curve 8520 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: 8 단계, 이미지 1/2 BlackBerry Curve 8520 Motherboard Replacement: 8 단계, 이미지 2/2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
결론
다른 32명이 해당 안내서를 완성하였습니다.
Matt
회원 가입일: 04/07/11
1,722 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G62
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 36,782
