주요 콘텐츠로 건너뛰기
BlackBerry Curve 8530 Keypad Replacement
필요한 것
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: 1 단계, 이미지 1/2 BlackBerry Curve 8530 Keypad Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Keypad Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: 3 단계, 이미지 1/2 BlackBerry Curve 8530 Keypad Replacement, Keypad: 3 단계, 이미지 2/2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Keypad Replacement: 4 단계, 이미지 1/2 BlackBerry Curve 8530 Keypad Replacement: 4 단계, 이미지 2/2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 1/3 BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 2/3 BlackBerry Curve 8530 Keypad Replacement: 5 단계, 이미지 3/3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Keypad Replacement: 6 단계, 이미지 1/2 BlackBerry Curve 8530 Keypad Replacement: 6 단계, 이미지 2/2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
결론
To reassemble the device, follow the instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Cory Davis
회원 가입일: 04/19/11
503 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 회원
CPSU-REGAN-S11S15G13
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 6,398
