주요 콘텐츠로 건너뛰기
BlackBerry Curve 8900 Antenna Replacement
필요한 것
  1. BlackBerry Curve 8900 Antenna Replacement, BlackBerry Curve 8900 Battery: 1 단계, 이미지 1/1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Antenna Replacement: 2 단계, 이미지 1/2 BlackBerry Curve 8900 Antenna Replacement: 2 단계, 이미지 2/2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Antenna Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Antenna Replacement: 4 단계, 이미지 1/1
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Antenna Replacement: 5 단계, 이미지 1/1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Antenna Replacement: 6 단계, 이미지 1/2 BlackBerry Curve 8900 Antenna Replacement: 6 단계, 이미지 2/2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Antenna Replacement: 7 단계, 이미지 1/2 BlackBerry Curve 8900 Antenna Replacement: 7 단계, 이미지 2/2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Antenna Replacement: 8 단계, 이미지 1/1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Antenna Replacement: 9 단계, 이미지 1/2 BlackBerry Curve 8900 Antenna Replacement: 9 단계, 이미지 2/2
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Antenna Replacement: 10 단계, 이미지 1/2 BlackBerry Curve 8900 Antenna Replacement: 10 단계, 이미지 2/2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
  11. BlackBerry Curve 8900 Antenna Replacement, Antenna: 11 단계, 이미지 1/1
    • Replace the entire center piece of the case to replace the antenna.
결론
Once all the steps have been completed, reassemble the device in reverse order.
Johnny Tran
회원 가입일: 09/10/11
473 평판
안내서 4개 작성하였습니다
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 5,837
