주요 콘텐츠로 건너뛰기
BlackBerry Curve 8900 Keypad Replacement
필요한 것
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: 1 단계, 이미지 1/1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: 2 단계, 이미지 1/1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: 3 단계, 이미지 1/1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: 4 단계, 이미지 1/1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: 5 단계, 이미지 1/1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: 6 단계, 이미지 1/3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: 6 단계, 이미지 2/3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: 6 단계, 이미지 3/3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Renae Bishop
회원 가입일: 09/07/11
68 평판
안내서 4개 작성하였습니다
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 6,877
