주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry Curve 8900 Microphone Replacement
필요한 것
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: 1 단계, 이미지 1개 중 1개
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    T6 Torx Screwdriver
    $9.99
  4. BlackBerry Curve 8900 Microphone Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
  5. BlackBerry Curve 8900 Microphone Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry Curve 8900 Microphone Replacement: 5 단계, 이미지 2개 중 2개
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: 7 단계, 이미지 2개 중 1개 BlackBerry Curve 8900 Microphone Replacement: 7 단계, 이미지 2개 중 2개
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: 9 단계, 이미지 1개 중 1개
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: 10 단계, 이미지 2개 중 1개 BlackBerry Curve 8900 Microphone Replacement: 10 단계, 이미지 2개 중 2개
    • Replace the entire motherboard to replace the microphone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Johnny Tran
회원 가입일: 09/10/11
473 평판
안내서 4개를 작성함
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 71
전체 시간: 4,802
