주요 콘텐츠로 건너뛰기
BlackBerry Curve 8900 Motherboard Replacement
필요한 것
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: 2 단계, 이미지 1/2 BlackBerry Curve 8900 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use your fingers to pinch the battery at the grey semi-circles on the edges of the battery and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Using a small iFixit opening tool, remove the lower rear cover.
  4. BlackBerry Curve 8900 Motherboard Replacement: 4 단계, 이미지 1/1
    • From the mid-frame of the device, use a screwdriver to remove the six screws.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Motherboard Replacement: 5 단계, 이미지 1/1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Motherboard Replacement: 6 단계, 이미지 1/2 BlackBerry Curve 8900 Motherboard Replacement: 6 단계, 이미지 2/2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case until the tabs are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: 7 단계, 이미지 1/2 BlackBerry Curve 8900 Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • In the same manner, disconnect the antenna from the motherboard.
  8. BlackBerry Curve 8900 Motherboard Replacement: 8 단계, 이미지 1/1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: 9 단계, 이미지 1/2 BlackBerry Curve 8900 Motherboard Replacement: 9 단계, 이미지 2/2
    • Gently remove the screen, taking care not to damage it by applying too much pressure.
  10. BlackBerry Curve 8900 Motherboard Replacement: 10 단계, 이미지 1/2 BlackBerry Curve 8900 Motherboard Replacement: 10 단계, 이미지 2/2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Johnny Tran
회원 가입일: 09/10/11
473 평판
안내서 4개 작성하였습니다
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 4,023
