주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry Curve 8900 Screen Replacement
필요한 것
  1. BlackBerry Curve 8900 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Open the rear panel to expose the battery and the chassis assembly. Remove the battery.
  2. BlackBerry Curve 8900 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a small, non-marring plastic opening tool to remove the lower-rear cover. (Credit cards and guitar picks work great.)
  3. BlackBerry Curve 8900 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to loosen and remove the six screws from the chassis as shown.
    • Flip the phone over to the front and remove the plastic bezel.
  4. BlackBerry Curve 8900 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the midframe from the back of the phone, which should now be free after removing the screws. The green motherboard should now be exposed.
  5. BlackBerry Curve 8900 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the front-cover by carefully prying the side release tabs, located on the side of the phone.
  6. BlackBerry Curve 8900 Screen Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry Curve 8900 Screen Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry Curve 8900 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Gently pry the side release tabs to lift the flexing keypad from the frame.
    • The navigation ball may come loose at this point. Set it aside with the keypad for reassembly.
  7. BlackBerry Curve 8900 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the motherboard.
    • Locate the screen's ribbon cable underneath the motherboard, and detach it from the phone.
  8. BlackBerry Curve 8900 Screen Replacement: 8 단계, 이미지 2개 중 1개 BlackBerry Curve 8900 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully pry at the sides of the screen until the display assembly is free. Remove the display from the motherboard unit.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Renae Bishop
회원 가입일: 09/07/11
68 평판
안내서 4개를 작성함
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 72
전체 시간: 4,676
