주요 콘텐츠로 건너뛰기
BlackBerry Curve 8900 Speaker Replacement
필요한 것
  1. BlackBerry Curve 8900 Speaker Replacement, BlackBerry Curve 8900 Battery: 1 단계, 이미지 1/1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Speaker Replacement: 2 단계, 이미지 1/2 BlackBerry Curve 8900 Speaker Replacement: 2 단계, 이미지 2/2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Speaker Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Speaker Replacement: 5 단계, 이미지 1/1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Speaker Replacement: 6 단계, 이미지 1/2 BlackBerry Curve 8900 Speaker Replacement: 6 단계, 이미지 2/2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Speaker Replacement: 7 단계, 이미지 1/2 BlackBerry Curve 8900 Speaker Replacement: 7 단계, 이미지 2/2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Speaker Replacement: 8 단계, 이미지 1/1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Speaker Replacement: 9 단계, 이미지 1/2 BlackBerry Curve 8900 Speaker Replacement: 9 단계, 이미지 2/2
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Speaker Replacement: 10 단계, 이미지 1/2 BlackBerry Curve 8900 Speaker Replacement: 10 단계, 이미지 2/2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
  11. BlackBerry Curve 8900 Speaker Replacement, Speaker: 11 단계, 이미지 1/1
    • Replace the entire center piece of the case to replace the speaker.
결론
Once completed steps. To reassemble your device, follow these instructions carefully in reverse order, starting from step 12 and ending with step 1.
다른 2명이 해당 안내서를 완성하였습니다.
Johnny Tran
회원 가입일: 09/10/11
473 평판
안내서 4개 작성하였습니다
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 7,847
