주요 콘텐츠로 건너뛰기
BlackBerry KEYone Motherboard Disassembly
필요한 것
  1. BlackBerry KEYone Motherboard Disassembly, The BlackBerry KEYone: 1 단계, 이미지 1/1
    • The start of our disassembly. The BlackBerry KEYone logo screen.
  2. BlackBerry KEYone Motherboard Disassembly, Remove the Sim Card Tray: 2 단계, 이미지 1/1
    • Use a sim card removal tool to remove the sim card.
  3. BlackBerry KEYone Motherboard Disassembly, Heat the top of the phone: 3 단계, 이미지 1/1
    • Apply heat to the top of the phone to remove the microphone plastic cover. There is a fair amount of adhesive holding this cover down.
  4. BlackBerry KEYone Motherboard Disassembly, Remove the Plastic Cover: 4 단계, 이미지 1/1
    • Use an iSesamo or other preferred pry tool to remove the plastic cover from the BlackBerry.
  5. BlackBerry KEYone Motherboard Disassembly, Remove two Phillips screws.: 5 단계, 이미지 1/1
    • Remove the two Phillips screws. They may be hiding under some adhesive.
  6. BlackBerry KEYone Motherboard Disassembly, Slide off the Plastic Top of the Phone: 6 단계, 이미지 1/1
    • The plastic top of the phone will slide off after removing the two screws.
  7. BlackBerry KEYone Motherboard Disassembly, Remove the Rear Plastic Battery Cover: 7 단계, 이미지 1/1
    • With the top plastic cover off it is pretty easy to use your preferred plastic pry tool and remove the battery cover.
  8. BlackBerry KEYone Motherboard Disassembly, Remove the Loud Speaker Cover: 8 단계, 이미지 1/1
    • Once the back cover is off remove the 7 Phillips Screws at the bottom of the phone that are covering the loudspeaker and the part of the motheboard where the USB type-C charging port is located.
  9. BlackBerry KEYone Motherboard Disassembly, Remove the Metal Flex Connector Bracket: 9 단계, 이미지 1/1
    • Removing the loud speaker cover will allow you to remove the other two Phillips screws for the metal bracket that covers up a couple flex connectors.
  10. BlackBerry KEYone Motherboard Disassembly, Disconnect the Battery: 10 단계, 이미지 1/1
    • Disconnect the two Phillips screws connecting the battery flex connector to the motherboard. Now you can remove the battery. There is ALOT of adhesive holding the battery in place. I recommend applying heat and using a plastic tool to slowly work the battery out. The volume and power flex runs under the battery. Be cautious near the top left.
  11. BlackBerry KEYone Motherboard Disassembly, Disconnect the Flex Cables: 11 단계, 이미지 1/1
    • With the battery out disconnect the three flex cables and remove the remaining two Phillips screws from this area of the motherboard.
  12. BlackBerry KEYone Motherboard Disassembly, Remove the Black Plastic Bracket: 12 단계, 이미지 1/1
    • There are three Phillips screws holding down a black plastic bracket that was previously partially covered by the silver bracket removed earlier. Two of the screws are visible without removing the silver top bracket but the third middle screws requires the top bracket be removed first.
  13. BlackBerry KEYone Motherboard Disassembly, Remove the Motherboard: 13 단계, 이미지 1/1
    • With all screws and brackets removed and all flex cables disconnected you can now remove the motherboard. I recommend starting at the top (Rear facing camera side) and removing the board top down because the charging port sits in the frame of the phone and will come out more easily last.
  14. BlackBerry KEYone Motherboard Disassembly, Done!: 14 단계, 이미지 1/1
    • All done the motherboard is out. Revealing the vibrate motor and headphone jack.
결론
다른 22명이 해당 안내서를 완성하였습니다.
Nathan Albertson
회원 가입일: 08/06/15
791 평판
안내서 1개 작성함
#TomatoBetChallenge #TomatoBetChallenge 회원
Business
1 회원
안내서 1개 작성하였습니다
댓글 20개
what about the screen on the front :)
Matt Howard - 답글
excellent. thanks. what about the keyboard? ;-)
joyce - 답글
Be great to have a screen replacement guide
smwduncan - 답글
Why the manufacturer always put so much adhesive on the battery??? To make it hard for people to install new ones?
johncklai - 답글
I don't think so. To prevent any form of movement.
ugbede ahiaba -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 18
전체 시간: 31,045
