소개
Follow this guide to install the battery in the Blackberry Pearl 8100.
  1. Before working on the phone, be sure that the phone is turned off. Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Before working on the phone, be sure that the phone is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    • Remove the battery located directly below back panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Robert Cronin
회원 가입일: 2010년 04월 08일
520 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-57, Forte Spring 2010 Cal Poly, Team 34-57, Forte Spring 2010 회원
CPSU-FORTE-S10S34G57
5 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 3,662
