주요 콘텐츠로 건너뛰기
BlackBerry Pearl 8100 Keyboard Replacement
필요한 것
  1. BlackBerry Pearl 8100 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Keyboard Replacement: 4 단계, 이미지 1/2 BlackBerry Pearl 8100 Keyboard Replacement: 4 단계, 이미지 2/2
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Keyboard Replacement: 5 단계, 이미지 1/1
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Keyboard Replacement: 6 단계, 이미지 1/1
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Keyboard Replacement: 7 단계, 이미지 1/2 BlackBerry Pearl 8100 Keyboard Replacement: 7 단계, 이미지 2/2
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Keyboard Replacement: 8 단계, 이미지 1/1
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Keyboard Replacement: 9 단계, 이미지 1/2 BlackBerry Pearl 8100 Keyboard Replacement: 9 단계, 이미지 2/2
    • Gently remove the keyboard from front casing. It should snap out of place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Robert Cronin
회원 가입일: 04/08/10
544 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-57, Forte Spring 2010 Cal Poly, Team 34-57, Forte Spring 2010 회원
CPSU-FORTE-S10S34G57
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 5,425
