소개
View the repair guide to install the Logic Board for the Blackberry Pearl 8100.
도구
부품
부품은 필요하지 않습니다.
Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
To place the screen on the new logic board, place the golden-colored filament in the slot above the screen’s position, similar to how the old one was placed. There are two pegs that fit into the logic board and secure it.
다른 3명이 해당 안내서를 완성하였습니다.
