주요 콘텐츠로 건너뛰기
BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
필요한 것
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 1 단계, 이미지 3개 중 1개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 1 단계, 이미지 3개 중 2개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 1 단계, 이미지 3개 중 3개
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 2 단계, 이미지 3개 중 1개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 2 단계, 이미지 3개 중 2개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 2 단계, 이미지 3개 중 3개
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 3 단계, 이미지 3개 중 1개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 3 단계, 이미지 3개 중 2개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 3 단계, 이미지 3개 중 3개
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 4 단계, 이미지 3개 중 1개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 4 단계, 이미지 3개 중 2개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 4 단계, 이미지 3개 중 3개
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 5 단계, 이미지 3개 중 1개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 5 단계, 이미지 3개 중 2개 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 5 단계, 이미지 3개 중 3개
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Ashley
회원 가입일: 04/15/13
318 평판
안내서 3개를 작성함
SUNY Cortland, Team 1-5, Getto Spring 2013 SUNY Cortland, Team 1-5, Getto Spring 2013 회원
SUNYCORT-GETTO-S13S1G5
3 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 854
