필요한 것
Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
Remove 1.55x.33mm Phillips screw from the metal frame.
Remove 1.5x4.25mm Phillips screw from speaker bar.
Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
Remove the battery connector using either your fingers or a pair of tweezers.
Remove the clipped ZIF data connector coming from underneath the motherboard.
Lift up the black plastic clip with a spudger.
Pull the connector out gently using tweezers.
Remove the following five screws from the motherboard.
Three 1.5x2.5mm Phillips screws
Two 1.55x2.38mm Phillips screws
Lift all four antenna connectors from the motherboard again using the spudger.
Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
Remove both screws attaching the metal mid-frame to the front panel.
Two Phillips screws
Unscrew the small blue boards in each corner with the same Phillips screwdriver.
Remove the sticker holding the touchscreen controller in place to free it from the mid-frame.
Unclip all attachments along the sides of the tablet.
Two large clips on the top of the device.
Four medium clips on the bottom of the device.
One small clip on the side of the device, near the headphone jack.
다른 7명이 해당 안내서를 완성하였습니다.
