주요 콘텐츠로 건너뛰기
BlackBerry PlayBook Motherboard Replacement
필요한 것
  1. BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: 1 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: 1 단계, 이미지 2/2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Motherboard Replacement, Motherboard: 2 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement, Motherboard: 2 단계, 이미지 2/2
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. BlackBerry PlayBook Motherboard Replacement: 3 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement: 3 단계, 이미지 2/2
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. BlackBerry PlayBook Motherboard Replacement: 4 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement: 4 단계, 이미지 2/2
  5. BlackBerry PlayBook Motherboard Replacement: 5 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement: 5 단계, 이미지 2/2
  6. BlackBerry PlayBook Motherboard Replacement: 6 단계, 이미지 1/3 BlackBerry PlayBook Motherboard Replacement: 6 단계, 이미지 2/3 BlackBerry PlayBook Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. BlackBerry PlayBook Motherboard Replacement, Unscrew Motherboard: 7 단계, 이미지 1/1
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. BlackBerry PlayBook Motherboard Replacement, Remove Wire Leads: 8 단계, 이미지 1/1
  9. BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: 9 단계, 이미지 1/2 BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: 9 단계, 이미지 2/2
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nathan
회원 가입일: 10/12/14
661 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 회원
CPSU-MANESS-F14S14G27
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 34
전체 시간: 3,301
