주요 콘텐츠로 건너뛰기
BlackBerry PlayBook Speaker Replacement
필요한 것
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: 1 단계, 이미지 1/2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: 1 단계, 이미지 2/2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: 2 단계, 이미지 1/1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: 3 단계, 이미지 1/2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: 3 단계, 이미지 2/2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: 4 단계, 이미지 1/2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: 4 단계, 이미지 2/2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: 5 단계, 이미지 1/1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: 6 단계, 이미지 1/2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: 6 단계, 이미지 2/2
    • Lift the right speaker bar to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan
회원 가입일: 10/12/14
661 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 회원
CPSU-MANESS-F14S14G27
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 971
