주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
If you're internal battery dies, use this guide to replace it.
부품
지정된 부품이 없습니다.
  1. Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
  2. Remove the backside of the device and set aside for later use.
    • Remove the backside of the device and set aside for later use.
  3. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
  4. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  5. Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
  6. Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break. Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
  7. Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
    • Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
  8. The conductor can now be easily removed by pulling it off of the logic board.
    • The conductor can now be easily removed by pulling it off of the logic board.
  9. Gently pull on the wires connecting the battery to the device until the battery disconnects. Gently pull on the wires connecting the battery to the device until the battery disconnects.
    • Gently pull on the wires connecting the battery to the device until the battery disconnects.
결론
Steven Jackowski
회원 가입일: 2010년 04월 18일
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 33-83, Johann Spring 2010 Cal Poly, Team 33-83, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G83
4 회원들
안내서 7개 작성하였습니다
What is the replacement battery
hoghead4734 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,170
