주요 콘텐츠로 건너뛰기
BlackBerry Storm 9530 Logic/Motherboard Replacement
필요한 것
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: 2 단계, 이미지 3개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 2 단계, 이미지 3개 중 2개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: 4 단계, 이미지 2개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: 5 단계, 이미지 3개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 5 단계, 이미지 3개 중 2개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: 8 단계, 이미지 2개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: 9 단계, 이미지 3개 중 1개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 9 단계, 이미지 3개 중 2개 BlackBerry Storm 9530 Logic/Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh Forester
회원 가입일: 11/28/10
2,623 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 9,687
