주요 콘텐츠로 건너뛰기
소개
Need to get inside your Blackberry Storm to fix it? Or just want to salvage parts? This is an easy to follow guide to do it!
부품
지정된 부품이 없습니다.
  1. Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. Turn your Storm where the battery door is facing up. Remove the battery door. Remove the battery.
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. Remove the two hex screws as shown by the SIM card slot.
    • Remove the two hex screws as shown by the SIM card slot.
  4. Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool. Remove the two hex screws underneath it.
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. Turn the phone over and remove the plastic cover under the buttons as shown. Remove the 2 screws underneath. Remove the 2 screws underneath.
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. Go around your device with the plastic pry tool, there a 3 clips on each side of the housing. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. You now have 3 pieces. The rear, mid , & front housing.
    • You now have 3 pieces. The rear, mid , & front housing.
  8. To remove the screen gently pry up this ribbon cable with a pry tool. To remove the screen gently pry up this ribbon cable with a pry tool.
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. To remove the main board from the mid housing disconnect the ribbon cable as pictured. Now follow in reverse order for reassembly! Now follow in reverse order for reassembly!
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
결론
다른 6명이 해당 안내서를 완성하였습니다.
Josh Forester
회원 가입일: 2010년 11월 28일
2,386 평판
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 9,448
