주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry Torch 9850 Battery Replacement
  1. BlackBerry Torch 9850 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure the device is disconnected from any charging cables
    • Press and hold down the power/end button on the phone until phone powers off and the screen goes black. Locate the power button on the lower-right face of the device
    • Press and hold the power button until the display shuts down and the screen remains completely black
  2. BlackBerry Torch 9850 Battery Replacement: 2 단계, 이미지 2개 중 1개 BlackBerry Torch 9850 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the batter cover release button at the bottom of the devices's rear panel
    • Press and hold the release button while simultaneously lifting the battery cover away from the chassis
    • Remove the cover completely and set it aside in a safe location
  3. BlackBerry Torch 9850 Battery Replacement: 3 단계, 이미지 3개 중 1개 BlackBerry Torch 9850 Battery Replacement: 3 단계, 이미지 3개 중 2개 BlackBerry Torch 9850 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery.
    • Once the plastic covering is removed, you can remove the battery.
    • Use your fingers or a plastic spudger to pop the bottom of the battery out of its place by pushing and lifting.
    • Once the bottom of the battery has ejected, you can easily remove the whole battery from the phone with your hands.
  4. BlackBerry Torch 9850 Battery Replacement: 4 단계, 이미지 2개 중 1개 BlackBerry Torch 9850 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Inserting a new battery.
    • Align the plus and minus signs at the top of the battery compartment with the plus and minus signs at the top of the battery.
    • Push battery into place.
    • Replace the plastic cover by snapping into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rachel Staigerwald
회원 가입일: 09/07/15
712 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 67
전체 시간: 983
