주요 콘텐츠로 건너뛰기
BlackBerry Torch 9860 Handset Disassembly
필요한 것
  1. BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: 1 단계, 이미지 1/2 BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: 1 단계, 이미지 2/2
    • Depress the battery cover release button and remove the battery cover
    • Remove the battery from the phone before continuing.
    • Slide the yellow button toward the battery to eject the SIM card
    • Remove the MicroSD card from the SD slot (if present)
  2. BlackBerry Torch 9860 Handset Disassembly: 2 단계, 이미지 1/2 BlackBerry Torch 9860 Handset Disassembly: 2 단계, 이미지 2/2
    • There will be a silver bezel around the edge (the dog ate mine!)
    • Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
  3. BlackBerry Torch 9860 Handset Disassembly: 3 단계, 이미지 1/2 BlackBerry Torch 9860 Handset Disassembly: 3 단계, 이미지 2/2
    • Grab your T5 Torx screwdriver, and remove all 8 screws
    • Be careful when taking out screws. The silver ones go in the corners, black ones in the middle
  4. BlackBerry Torch 9860 Handset Disassembly: 4 단계, 이미지 1/2 BlackBerry Torch 9860 Handset Disassembly: 4 단계, 이미지 2/2
    • With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
    • Gently pry ribbon cable off, and then you will have the back cover fully removed
  5. BlackBerry Torch 9860 Handset Disassembly: 5 단계, 이미지 1/3 BlackBerry Torch 9860 Handset Disassembly: 5 단계, 이미지 2/3 BlackBerry Torch 9860 Handset Disassembly: 5 단계, 이미지 3/3
    • The next step is to remove the board.
    • There are 3 ribbon cables connected to it
    • Disconnect the first ribbon cable
    • When you remove the second ribbon cable it will reveal the third ribbon cable
  6. BlackBerry Torch 9860 Handset Disassembly: 6 단계, 이미지 1/3 BlackBerry Torch 9860 Handset Disassembly: 6 단계, 이미지 2/3 BlackBerry Torch 9860 Handset Disassembly: 6 단계, 이미지 3/3
    • With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
    • With the board removed, you can then simply lift out the LCD display
  7. BlackBerry Torch 9860 Handset Disassembly: 7 단계, 이미지 1/1
    • Once the LCD is removed, the handset disassembled.
결론
다른 7명이 해당 안내서를 완성하였습니다.
daniel
회원 가입일: 12/22/11
380 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 7,060
