주요 콘텐츠로 건너뛰기
BlackBerry Tour 9630 LCD Screen Replacement
필요한 것
  1. BlackBerry Tour 9630 LCD Screen Replacement, Battery: 1 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Position the phone so that the keyboard is facing down and the back is facing up.
  2. BlackBerry Tour 9630 LCD Screen Replacement: 2 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Push the center silver button upwards to release the back cover.
    • Take the back cover off and set it to the side.
  3. BlackBerry Tour 9630 LCD Screen Replacement: 3 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Grip the battery where the light grey half circles are located and pull up.
    • Set the removed battery to the side with the back cover.
  4. BlackBerry Tour 9630 LCD Screen Replacement, Keypad: 4 단계, 이미지 1/1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 LCD Screen Replacement: 5 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Using an opening tool, pry the top plastic covering off. As shown in the second picture.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the back casing.
    • This may take some wiggling to fully remove the part.
  8. BlackBerry Tour 9630 LCD Screen Replacement: 8 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Using a small opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 LCD Screen Replacement: 9 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement: 9 단계, 이미지 2/2
    • Using a small opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 LCD Screen Replacement: 10 단계, 이미지 1/1
    • Gently push up on the keyboard from below to snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 LCD Screen Replacement: 11 단계, 이미지 1/1
    • Remove the keypad.
  12. BlackBerry Tour 9630 LCD Screen Replacement, LCD Screen: 12 단계, 이미지 1/2 BlackBerry Tour 9630 LCD Screen Replacement, LCD Screen: 12 단계, 이미지 2/2
    • Gently lift the motherboard to expose several ribbon cables.
    • Use the small plastic opening tool to disconnect the orange LCD ribbon from the square end of the ribbon cables.
  13. BlackBerry Tour 9630 LCD Screen Replacement: 13 단계, 이미지 1/1
    • Flip the phone over. Using the large plastic opening tool, pry the LCD screen from the motherboard.
    • Replace the LCD screen
    • The LCD screen is held in place with glue.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mia
회원 가입일: 01/13/15
524 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 914
