소개
If your trackball is unresponsive or damaged, then you will need to replace it. Use these step-by-step instructions to replace your trackball on a Blackberry Tour 9630.
필요한 것
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
